1 - 12 of 12 Posts
Can anyone tell me what this plug is for?
322506
Discussion Starter · #2 ·
It's on a 2013 WRX hatchback
Super Moderator
For an option you don't have, possibly a factory test device, any number of things. I don't see a mating wire so i suspect it's not important.
Do the 13s have the green test connectors under the dash? If so then the car will give you an Xmas tree light show if you connect them. IDK, I’ve got a bugeye and it does definitely.
Discussion Starter · #5 ·
Thank you guys. I have them plugged together in the picture and it gave me a ton of codes when I started it with them plugged in.
I keep pulling a ROM failure when I hook up my Accessport. And I get an over boost at WOT in 3rd... I'm going crazy trying to hunt this down.
Æternum
They shouldn't... At least no CAN vehicles should need a test connector.
Then again, my memory ain't so sharp these days.
  • Like
Reactions: Allroy1967
Don’t hunt anything down. Just disconnect them and live life.
Discussion Starter · #9 ·
Thank you I kinda figured that's what it was. I have been trying to hunt this problem down.
322654
Discussion Starter · #10 ·
I get the P0605 everytime I hook the accessport up.
Super Moderator
I would contact cobb about that one. It may be the ECU was locked by a previous tuner or you got a bad flash. I know some other errant issues can cause that code as well
Discussion Starter · #12 ·
I had it on the car before and it worked great. I took it to the dealer for the road bearing recall and put the stock stuff back on. Hasn't worked since. Super frustrating
1 - 12 of 12 Posts
