I'm confused - I'd like to change my transmission fluid, but I'm not sure which is better - Redline 75W90NS or Redline Shockproof?
I'm leaning towards the Shockproof because it seems like it provides more protection.
Which weight of Shockproof would I use - Lightweight or Superlight?
This statement from Redline's website has only made me more confused:
Thanks
Does the Shockproof gear oil have a GL-5 rating? Would this ever be a concern if a warranty repair was ever needed?The Heavy can be rated as a 75W250 Gear Oil, but has the lower internal fluid friction of an SAE 75W90. The LightWeight can be rated as a 75W140 Gear Oil, but has the lower internal fluid friction of an SAE 30 motor oil. The SuperLight can be rated as a 70W90 Gear Oil, but has the lower internal fluid friction of an ATF.
Thanks
