I have been searching both clubs and all of my bookmarks and cannot find the wiring diagram for the stock subwoofer harness. Anyone willing to help?
Here's what I did. I bought a line out convertor and a stereo install kit you can find at Good Guys or some electronics store.
I tapped into the stock sub wiring harness with the wires coming from the line out convertor. I mounted the line out convertor underneath the center console, ran the rca cables out the back of the line out convertor underneath the carpet and the back seat and into the trunk.
You will have to run the main power wire for the amp from the engine compartment off of the battery, through the grommet in the firewall on the drivers side, underneath the dash, underneath the center console, underneath the carpet and the seats as well. Then the only hard part is finding a good grounding point for your amp in the trunk. If I ever have to take out the center console again I will take detailed pictures and post them in the audio section.
I also ran the remote switch from the battery through the new mess of wires and mounted a power switch in the center console. The other side of the remote switch goes to the cigarette lighter since that is an ignition wire. I believe the wire I used from the cigarette lighter was yellow. This way I can turn the amp on and off at will.
Sorry I can't be of more help. I did this install over 6 months ago.
Good luck.
Kurlee Daddee
(THE ORIGINAL
