Yes, it's the same effect.Not to steal the thread, but I've been wondering about this as well. Will getting wheels with a lesser offset have negative effects just as a wheel spacer would? It makes sense that it would be the same, but I'm thinking with wider tires it wouldn't hurt the ball joints as much because that would move more area of the tire underneath the car, unlike wheel spacers. I'm pretty sure my stockers are at +53 so I was wondering how much less would lead to trouble, and what's possible to get away with.
What size spacers?so spacers will have negative effect? looks like im returning it then.
A wider wheel also balances the offset.
Sent from my SAMSUNG-SM-G890A using Tapatalk
To the extent that the additional width and the reduced offset place the edge of the rim of the wheel at the same spot with respect to the fender lip.just as some clarification (no thread hijack)
when you say a wider wheel balances the offset...
by "balances the offset", does that mean going with a wider wheel allows you to have lower offset (to a degree) without any changes
I was told by a shop that wheel spacers are a great tool but unless you dont spend $$$ then it isn't worth it. If you can't fork up the money for good quality spacers then i suggest not doing them. Also i was told that if you want your wheels to be sticking out more then the best option is to get rims with a better offset. Actually the recommended part is rims with offset rather than spacers. Adding another component to your car can give your car another reason to fail. To be honest i personally want spacers because im too poor to buy RIMS and WHEELS all at once.Hey guys,
i just bought a couple sets of subispeed wheel spacers. i am trying to get that aggressive look. any thoughts on them? will the ride be different?
That shop lied to you. Wheel spacers are never ok.I was told by a shop that wheel spacers are a great tool but unless you dont spend $$$ then it isn't worth it. If you can't fork up the money for good quality spacers then i suggest not doing them. Also i was told that if you want your wheels to be sticking out more then the best option is to get rims with a better offset. Actually the recommended part is rims with offset rather than spacers. Adding another component to your car can give your car another reason to fail. To be honest i personally want spacers because im too poor to buy RIMS and WHEELS all at once.
Also, as stated a couple posts above, running wheels with different offsets can cause problems too. It's basically the same as a spacer but with less stress on the lug bolts.I was told by a shop that wheel spacers are a great tool but unless you dont spend $$$ then it isn't worth it. If you can't fork up the money for good quality spacers then i suggest not doing them. Also i was told that if you want your wheels to be sticking out more then the best option is to get rims with a better offset. Actually the recommended part is rims with offset rather than spacers. Adding another component to your car can give your car another reason to fail. To be honest i personally want spacers because im too poor to buy RIMS and WHEELS all at once.
RIMS and WHEELS
