1 - 9 of 9 Posts
If i were to get 4 Michelin Pilot Super Sport size 225/45-17, would any 17 inch rim fit it, or is there a size i need? I'm upgrading from a 205 r16 to a 225 r17.
:confused:
Sammich Makin' Pwincess
the width & offset of the wheel is important.
are there any ones specifically that you had in mind?
well i have 17x7 +48 on 225's.
you should pick an offset in the high 40 range.
as far as width, i'm honestly not 100% sure but you can probably get away with 17x7.5 or maybe even 17x8. [someone else can chime in]
also- make sure the offset [5x100 for wrx & 04 sti.. or 5x114.3 for 05+ sti's] & hub bore is correct before you buy them.
17X8 5-100 47GM is what I found... Im guessing the 47gm is offset (Witch btw, I have no clue what off set is haha), and the 5-100 is right because I have an 04 WRX (not sti, And not sure what 5-100 is referring to, and why.) But the Hub bore I'm completely lost on.. I'm a new at this lol and thanks for your help so far..
1 - 9 of 9 Posts
