1 - 4 of 4 Posts
I am assuming that an 18" wheel has more diameter that a 16". So what do you guys with 17"-18" wheel use for a spare if you get a flat in the rear? If you have one tire larger than the other you will burn your limited slip up because it would always be slipping due to the difference in wheel speed. Also would the ABS freak out with 2 different wheel speeds? I guess calling a tow truck is the answer. How do you recalibrate you speedo? So many question so little time. Thanks guys.
Thinking Man's Engine
205/55 r16 translate to inches in diameter (total)
205 (width)*0.55 (aspect ratio)*2 (top and bottom)/25.4 (mm to inch conversion) +16 (rim diameter)= 24.88 inches total diameter.
Let's assume a 225/40 r18 tire size, this results in 25.08 inches, the difference is 0.80 % larger in diameter, basically neglegible.
The max % difference in diameter allowed is 3%, plus or minus.
1 - 4 of 4 Posts
