1 - 12 of 12 Posts
I have a 2007 wrx wagon. I am buying new rims, but not sure if they will fit without any major clearance issues.
Rims esr sr01 18x8.5
Super Moderator
Yes.
if its not between +42 and +50 you are likely going to need to need a roll in the rear if you put on a 235/245 tire and have any type of suspension lowering.
If you are pretty low you are going to need a roll with almost any 8.5 inch wheel and corresponding tire in the rear
I also would advise against BC racing
Lowest budget coilover I would go is probably ST because they are made by KW
1 - 12 of 12 Posts
