probably a smarter idea to do it that way lolThank you for all the advise.Will try out these tomorrow.
I was going to get just the bearing.But turns out I need a press & slide hammer to get the bearing off the hub.Both of which I do not have.I found it cheaper to just get the hub assembly.
Yes,I will be getting an alignment afterwards.I don't know how your hub is mounted but it might be a good idea to get an alignment done afterwards.
Sent from my SGH-T959 using Tapatalk
This alone is almost reason enough to want an '08+. At least Subaru saw their way to clarity on that particular issue. Ordering all of the parts then doing the install or having them installed is just a pain on pre-'08 WRX's.We don't have that option - it would be my preference.
I agree it is a PITA - however mine have all been fine (we had to do one on the '98 Outback). It is almost always more economical to keep an older car when you add everything up.This alone is almost reason enough to want an '08+. At least Subaru saw their way to clarity on that particular issue. Ordering all of the parts then doing the install or having them installed is just a pain on pre-'08 WRX's.
Its a Honda CRV.They are notorious for bad wheel bearings.A noisy wheel bearing doesn't always have play. A loose wheel bearing doesn't always make noise.
When you apply more sideways force such as being the outside wheel in the turn, the bearing will get louder.
You may or may not need an alignment. Don't waste your money if you don't. It all depends on what needs to be disturbed to change the bearing. What kind of SUV is it?
Perhaps it isn't a bearing at all. The tire could be cupped or have a shifted belt.Its a Honda CRV.They are notorious for bad wheel bearings.
Looks like I don't need an alignment.
None of the said methods worked.Someone else drove the car while I tried to listen to the sound.Seems to be coming from the rear right.
I would have taken it to a shop but I asked & they want around $400 .The dealer wants $65 an hour(5 hour job) plus cost of parts.
The bearing costs just $80.The hub assembly costs $150.
I actually removed & checked all 4 tires today.All have even wear & I didn't see anything out of the ordinary.Perhaps it isn't a bearing at all. The tire could be cupped or have a shifted belt.
What is the noise you're hearing?
If the pitch doesn't change with cornering load it's doubtful the bearing is bad.I actually removed & checked all 4 tires today.All have even wear & I didn't see anything out of the ordinary.
It is a whirring noise.It starts at about 30 mph & increases with speed.
