1 - 14 of 14 Posts
hello
i have a 02 wrx wagon
i have a few modifications and want to know whats the next best mod for a reasonable price
modification already installed
megan coil overs and front n rear strut tower brace
blow off valve
aluminum radiator
down pipe
exhaust
and a tune
i wanted to get some advice in whats my next big mod
that will be perfect for my 02 wrx wagon that has 164k miles
would a turbo upgrade with wastgate
or what ????
What about a brake upgrade? Or bushings? Those would be my next purchases
Getting rid of the Megan Racing coilovers
Sent from my Droid using Tapatalk
+1,452,958 do that and replace them with some RCE yellows and some good struts like Tokico or KYB.
What tune are you running? Is it a tune that was done with all those mods in place?
Get some better brake pads and bleed your brake fluid and replace it with some high performance stuff.
Then next on the list would be some better sway bars.
At this point your next best mod(s) would be to ditch the sh*tty coilovers and replace the blowoff valve with a stock BPV. And then the obvious, get a catless uppipe, and a protune wouldn't hurt.
A: I'm lowered and kinda like it cuz it feels like a gocart...but I don't really think it helped my handling at all. Plus the PO did it so I don't really care. But that BOV isn't doing anything but hurting you, it messes with the a/f ratio pretty bad. Put the stock BPV back on. Get a catless up pipe. Could try sway bars, they help alot with handling and are relatively cheap. And don't require a tune.
It's not that being lowered is such a bad thing (to a point), it's the fact the the Megan coil overs he has are notoriously poorly made..
Do they make yellows for his car??
They make them for the sedan, maybe use spacers for a wagon.
hate to threadjack but I couldn't find any other than for the STI with a quick search. Guess I should look more for when I do struts/springs
Turn in Concepts sells them for 02-03 WRX.. they even sell decked out Tokico D-Specs fully assembled with RCE Yellows an your choice of top hats, like Whiteline Com C's.
Turn in Concepts
AH, thank you. I promise I looked and just couldn't find them lol. Now if they would just do it with Kyb's so the price doesn't end up so damn high lol
1 - 14 of 14 Posts
