1 - 7 of 7 Posts
Looking through the turtorials and found this -
Battery Grounding
What the hell does this do?
That depends on who you ask.
Some say it makes a dramatic difference in the quality of signal various sensors get, and so it'll make the car run smoother.
Others say it does nothing.
Others still say it's a waste of time and money.
Well i stopped getting zapped by my door when i did it.
started in japan as a common cheap mod that is very effective for the function of electronic accessories, as well as making decent power gains on high powered cars. those motors already pumping 500+hp gained something like 15hp. although it makes every accessory work better, power gains are not really seen on lower powered cars. the more power you make, the more power this mod makes.
you don't have to start from the same terminal on the battery either... you can make a loop, continuing the next connection from the previous ground.
I did it for 35 bucks....it was worth the money. Idled smoother, felt like it had a little more oomph up top, all lights were brighter, and didn't get shocked anymore when getting out of the car. Can't really go wrong for that price.
look up www.paranoidfabrications.com
its a nice mod if you have aftermarket stereo equipment that draws a lot of power like amps and such, with all OEM electricals (or even some low power aftermarket ones) its pretty much a waste.
1 - 7 of 7 Posts
