1 - 6 of 6 Posts
I can't seem to find what kind or size of turbo is in my '11 Wrx. Or what psi from the factory it is. Is it a Mitsubishi turbo? That would seem odd. Anyhow I'm also looking to find out what my max whp could be using stock turbo?
He must have used Bing.
Doesn't work that way. Every dyno is different. Contact your tuner and ask what their best results are; that will yield the most accurate answer.
Sent from my Droid using Tapatalk
My stock turbo is a Mitsubishi. Yours is not. Mitsubishi turbos are among the most reliable in the world.
Stock boost is about 15.5psi max at sea level, you have an IHI VF52 turbo, and as EJ said, WHP is determined by a lot of factors but I've seen posts of 350WHP from a VF52, yours may be different.
1 - 6 of 6 Posts
