1 - 3 of 3 Posts
what kind of diffs are we running in the back and in the center. i know the front is open and the rear is limited slip right? but what kind of lsd? its not a clutch type is it? or is it torsional? and is the center diff viscous?
thanks
Discussion Starter · #3 ·
also how does a torsinal diff work i checked out howstuffworks and i got a small understanding and a friend tried to describe it to me and i just couldnt really get it.
so when one starts to slip it starts to drive another set or gears(two of them) and these two have a set gear ratios and depending on the gear ratio it will send that much more torque to the none slipping one. is this correct? if this is correct how do they get the second set of gears moving once one slips?
thanks
1 - 3 of 3 Posts
