1 - 4 of 4 Posts
2008 SSM WRX Hatch
New Turbosmart iwg actuator on the way and I was going to replace the 5psi spring with 7psi but now I'm thinking I should have gotten a 10psi spring..
'08 wrx hatch TP stage2 etune @ 18psi target and I have a 3port ebcs. Plan on getting map revised immediately but which would be better so I don't have to do this twice. I have plenty time as the wastegate is coming from AU, probably a month out.
Æternum
I think you'll be fine.
Plenty of TD04-13Ts (yeah, I know you have a 19T) with maxxed pressure ratios on OEM wastegate and spring. You are unlikely to have an issue in controlling boost at 18 PSI even with the stock wastegate.
2008 SSM WRX Hatch
Discussion Starter · #3 ·
Thanks man.
Yeah I think the vf turbos have a 7psi spring stock so if it's good enough for them I would think it would work for me and my tiny td04. Just got thrown off by people saying the spring pressure shouldn't be less than the target when multiplied by 2 seeing as the tune is 18psi now. I'll check with the tuner Monday for sure too.
Æternum
Thanks man.
Yes, I've heard that rule of thumb. There are caveats. This is a dynamic system so you can't really reference static pressures anyway.
1 - 4 of 4 Posts
