1 - 20 of 28 Posts
Well i went the Cheapo way and got my self a Sport Comp 2 1/16
Boost gauge and a Autometer Cup...
Looks very nice and matches the Stock Guages...rather nice compared to my expectations...
I know its a Cheap POS...
So the Question is What does your Autometer Read at WOT
Mine:
1st : 11 psi
2nd: 11.5 psi
3rd: 12-12.5 psi
4th: 12-12.5 psi
5th: 13.5 psi
Shouldnt the car have max Boost in 3rd Gear instead of getting max boost all the way into 5th Gear
_______________________________________
04 WRB Wrx
weeee
ok, mine was...
idle - 19.5 in. hg.
1st - ~ 11 psi
2nd - 12 psi
3rd - 12.5 psi
4th - 13 psi
5th - touched 15 for a split second then went down to 13.5 psi
autometer boost gauges arent notorious for their accuracy so you gotta take it with a grain of salt. check where the needle is when the engine is off and see if youre within the 0. closer to the center the better. rumor has it the needle can drift one way or another off center of 0 and throw off its accuracy. mines a little below dead center 0.
im hoping to upgrade to defi gauges next summer.
oh, and btw, anytime you want me to test my max boost im game
:D
Thanks for your help...
my needle does rest on the far edge of zero towards the vaccum side...
probably why i dont see full boost in third?
That's a mechanical gauge, right? If so, is there possibly a pinched line? Probably not but its something to investigate.
Back when I had Autometers (first Sport-Comp then Cobalt) I had no problems with accuracy...
If you are using the lines and fittings that they supplied then I would replace them ASAP. I had to piece together the fittings from a plumbing store but it was worth it. I used all brass fittings and I'm not 100% sure of the sizes but here's a quick diagram of what I used.
Oh yeah, to answer your first question. I have an Autometer CF boost gauge and it sets just above zero when off and I peak at ~15-15.5 psi then settles at ~13.5-14 psi.
Discussion Starter #9
Thanks for the info...i used a sort or of a Y pipe to tap into the BOV line in instead of using the Tee connector..i also used the 1/8 nylon hose that came with the gauge
Discussion Starter #10
Ok finally did my 3/16th mod on my 04 WRX...
Now the Boost reads as follows..
1st : 12 psi spikes to 12.5
2nd: 13 psi spiking to 13.5
3rd: 13.5 psi spiking to 14.1psi
4th: 13.5 psi spiking to 14.1psi
5th: 13.5 psi spiking to 14.1psi
Yes the 3/16th mod worked for me without major spikes ...
acutally car does seem to pull a wee bit more...
Fyi It is not a POS, It's a good way to save about 200 dollars instead of blowing your money on some lame Defi (read: Overpriced) gauge.
IMHO
I've got autometers sitting at my house for whenever I get a free weekend from college and can run home and install them.
They are all sitting at zero right now :cool:
I was planning on running some normal vacuum tubing instead of their nylon junk that it came with. Whats wrong with the fittings?
ClubWRX.net Vendor
IMHO
Easy there tiger! The Defi gauges cost more not due to them being pretty, but because they are high quality performance items. Just like your WRX. If you were to transplant this train of though to your vehicle, you should've bought a DAEWOO, not a WRX, correct?
Granted, the Defi's do cost an arm and a leg. Yes, you can get a good gauge for much less. I, for example, bought Blitz BL's (no longer in production). They work fine, were half the price of the Defi gauges, but having seen the Defi in real life, makes me a believer that they are worth the money, as they are nicer and better gauges. The question with 'exotic' items, such as these, is not whether they are worth it, but whether their price and your bank account can agree with one another on finding you happiness. If not, buy a less expensive, not cheaper, gauge and move on. No need to spread your hate towards those who can, have, and do, simply because you can't, have not, or won't.
If I had the money I would definately get some Defi gauges but instead I got my gauge pod for free and the three gauges (boost, tranny temp, EGT) for $260.
I am not a rich person by any means and I figure gauges are gauges to a point. I realize that my autometers will not be as accurate as your Defis (even though they say that they have been accuracy tested or something on the back of the gauge, I'll take a pic), I got 3 gauges for the price of a single Defi and they work for me.
ClubWRX.net Vendor
I don't have Defi gauges. But I wish I did. If I could do it over, I would have waited and bought the Defi's. Again, how you use the gauges is more important than how much you paid, or who made them. The hardcore enthusiast will pay anything, the one's who just want to keep an eye on things (me) will look for less expensive alternatives. Your autometer, and my Blitz gauges will surely inform us if a major problem is occuring, which is what they're for. There's nothing wrong with the autometer gauge. For someone to say so is naive, and very stupid. All I wanted to say was that the Defi gauges are very nice, and I, as would you, would pay the money had we seen these things in real life before we bought our current gauges. They're soooo nice!!!!
not sure about all of my other gears but 3rd 4th and 5th all hold right at 14psi sometimes spiking to 15-15.5 i'm running there phantom series gauge, also have adjusted wastegate 2 turns in
The fittings probably work fine but I just prefer the barbed. Under the hood, I would say definitely use a brass barbed tee because of temperatures but at the gauge it can be tricky to make it fit in a pod. The main thing is the nylon, it gets holes very easy. Also it doesn't have to be huge either. I'm pretty sure I used 1/8" and it's VERY responsive. It's pretty much instantaneous. I'll try to get pics of mine soon.
while we're on the subject of boost gauges... (dont mean to hi jack) does anyone else's make a buzzing noise at high rpm's? not sure if its the gauge or the pod, just thought i'd ask...
Mine doesnt.
1 - 20 of 28 Posts
