1 - 9 of 9 Posts
I just istalled the joe p mbc and an autometer boost gauge
i have it set at 15psi right now
WOW what a difference i love it
the mbc took 5 mins i timed it
the boost gauge took 25mins
ill post pics later
I also installed and tuned my MBC yesterday. It was quite simple, however dialing it in took me a little more than two hours.
It peaks in fourth at 0.107 megapascals :) which is ~15.5 PSI.
Had a question...where did you all mount the device?
Discussion Starter · #4 ·
here is some pics of my Joe P mbc installed and where i tapped for the boost gauge
and now i feel the POWER
I mounted my Joe P with a zip tie to the black bracket above and to the left of the turbo. It has a square hole in it and holds the boost controller quite securely.
-Jim
That was actually PlatinumWRX who said that...I just quoted him.
But I found that empty hose clip also and mounted mine there too. VERY convenient. And kinda stealthy too.
Sorry about that SI2WRX. Ment to refer to Platinum's post. I'm glad you like the location. It works great for initial setup and when further adjustments are needed since the bracket holds it nice and tight.
Shawn
1 - 9 of 9 Posts
