1 - 9 of 9 Posts
Got my car fixed now running into a random starting issue it starts then dies. My car hit fuel cut before my boost was fixed and i got a injen cai and a greddy cat back new plugs in the rebuild so could it be maf issue or a bad ground? Checkin my codes tonite
Post when you have codes...
What was wrong that you got fixed?
I had a tech at work replace my turbo inlet and he tore it apart and told me he didnt know how to put it back together. He crushed the nipple on the right side of the turbo so i had to get a new turbo. So i towed it to subaru then they put it together. Now every so often it wont start right. Will post codes later
My codes are p0171 and p0546
MAF issue probably caused by your intake
EGT issue possibly caused by who knows what at this point
any tune or just the mods?
how long since the Subaru work? How long after the work did the problem start?
Good news, everyone!
Sounds like a leak in the intake tract somewhere.
Discussion Starter #7
My starting issue happened the day it got put back together i hit fuel cut due to overboost due to bad turbo. I was runnin a typhoon short ram prior to the subaru work it hasnt done it in awhile so im leaning towards bad maf or electrical issue and no tune yet
Pro Manscaper
Get rid of the Injen CAI. They are garbage.
Discussion Starter #9
Ok so should i go back to the typhoon? And why is it garbage?
1 - 9 of 9 Posts
