1 - 20 of 95 Posts
Moderator
Discussion Starter · #11 · (Edited)
11 - this is the float switch that I installed to light up a LED in the cabin when the level gets low. The switch is installed about 25mm above where the system draws its water from.
Moderator
Discussion Starter · #14 ·
A real quick update. A run to Blockbuster and home yeilded a face like this -> :D The Power Meter iD gave me an increase from 224kW to 244kW. Not actual figures but the % increase is interesting to note. EGTs are down by about 25-50C.
More info on Monday night or Tuesday as I am off for the weekend!!!
Is the 2D the one that is programmable or that is driven by an Engine management system.
Aha, I forgot about that one :D Are you running some form of engine management or was that extra power just due to a cooler charge temp?
1 - 20 of 95 Posts
