1 - 9 of 9 Posts
I've found a vf39 with 5,400 miles on it . The guy says " it has the typical vf39 hairline crack by the wastegate but does not affect the performance" should I or should I not buy this turbo ? Thanks for any info.
Administrator ...De Rerum Natura
The hairline cracks are perfectly typical.
How much is he asking?
250, and thanks for the quick answer
Assuming everything is legit then yes that sounds like a good deal.
i heard you get that crack when you boost while the engine is cold. truth? fact? speculation? appears the crack doesn't effect performance. $250 is a really good deal. they go for $400 or more on ebay generally.
also ask if there is any shaft play or damaged fins
that's a great price if it's in good working order
Discussion Starter #9
There was no shaft play . However the guy already got rid of it (bummer):unhappy:
1 - 9 of 9 Posts
