I am taking my heads in from my '06 WRX Limited wagon to a local head shop to have them checked out and rebuilt as needed. I was hoping someone in the club could give me a little education on what I should expect from the machine shop as far as cost and things that should definitely be replaced on the heads. The reason for having the work done is that I was pretty sure I had a burnt or not sealing for some reason exhaust valve. I deduced this by putting the engine at TDC and blowing compressed air into each cylinder and listening to the exhaust pipe for air leak. I had a leak in the #3 cylinder only. The car had overheated a couple times because of cooling system failure prior to the engine issues arising. The issues were rough idle, misfires.
I was thinking about purchasing a HG kit online, and was wondering if anyone could suggest the best kit for the buck, and what the part number for my car would be. 2006 WRX limited turbo EJ25. I have read through a lot of the post about head gaskets and it sounds like it is best to use OEM, sixstar, or Felpro (although some people have had issues with the felpro). So my main question is what parts will I definitely need to replace, because I am going to go ahead and buy them now, and then deal with the rest after the shop does their diagnosis. If anyone has the part numbers for all the parts that would be much appreciated. I keep seeing Evergreen and Gates manufactures for a lot of the parts I am going to be needing, does anyone know if they are any good? Their prices sure are good, but as the saying goes you get what you pay for, which makes me a little hesitant to buy the cheapest.
Thanks for taking the time to anyone who responds.
