1 - 7 of 7 Posts
I have an offer, but I think I can do better. Way too much to list, but I'll give it a try.
EJ20 with Crower con-rods, JE forged pistons, cometic head gaskets, ARP head studs, MRT dogbox tranny(complete) with upgraded shift forks, better center diff, shifter interlock, three different ratio 4th gear sets ($9000 for tranny new, $600 for each extra gear set), Two AVO garrett dual ballbearing turbos, 320 and 500, Top mount IC, snow alchohol inj kit, NO2 with two bottles, eight point roll cage, racing seats with custom brackets, five point harness, MOMO wheel, four 16"SSR wheels (look like new!), two 15"SSR wheels (never put on car)(have M&H DOT slicks on them for RWD conversion), two Micky Thompson ET streets for rear (little use), STi rear diff and OEM rear diff, STi axles and OEM axles, STi rear hubs/bearings/spindles, extra new STi hub/bearings/spindle(All STi stuff was new from factory, not from a wrecked car) Three different driveshafts, one is a one piece aluminum 800HP unit, MOROSO fuel cooler, MSD fuel pump booster, Unichip with two different MAPS, 116octane w/nitrous, and street. STi injectors, and OEM inj. AVO flywheel, new AVO adj. fuel pressure reg. MRT fuel rails with many different ends, and two OEM fuel pressure regs. Boston Acustic speakers, four channel amp, Bass box (out of car, but goes with car) Aluminum drag wing on rear of trunk lid (adjustable), much more! Over $50,000 worth of stuff. Car has about 10,000 miles on it, STi rear has about 300miles on it. Car was built for RWD, but never did weld up center diff., two TXS boost controlers, one has a solonoid ans switch, BIG hood scoop, and OEM scoop. I was thinking about $19,000 for all of it. Easy to part car out and make some $$, but I'm lazy now.
Scott
804-754-0907h
804-285-0777w
This post has been edited by turbo2nr on Jan 15 2005, 10:29 AM
This space for rent.
Car has about 12,400 miles on it now. I'll take $17,000, but if you want to give me more, I'll be glad to help you. Many more parts go with car, too much to list. OEM service manual printed and in six 3", three ring binders. (cost $100 just to print), Turbosmart BOV, much more. Call if any questions, or setting up a time to drive car. :)
STi silicone radiator hoses, Crucial thermostat, much more.
it would cost you over $50,000 for all this new! What a deal! :thumbup:
Discussion Starter #7
car is sold.......Anyone need tranny repaired, or replaced, or upgraded, I'll be glad to help. I'm in Richmond VA.
804-754-0907
1 - 7 of 7 Posts
