1 - 2 of 2 Posts
Anybody out there have a map for a VF23 to give me some sort of a starting point? If not, which one of the other TXS Stg.4 maps can I use as a base? I'm going to ask over on wrxhackers, but this place gets a lot more traffic. Thanks!
I think if you started with a vf34 map you'd be in good shape...boost comes on a little earlier, and it'll run a little bit rich (advance timing some, cut some fuel) and you should be fine. Sorry I can't be more helpful, but I'm still runing the Prodrive ECU...
~Tim
1 - 2 of 2 Posts
