1 - 4 of 4 Posts
The UTEC i have purchased is used and does not have the ABC with it....yeah i know but i got it for 400 bucks. Anyways. I have an MBC installed that is not the txs ABC. Is this going to work for me? ALso i have modified stock injectors instead of the STis. How do i go about scaling the injectors? I have a little acrobat file explaining something about revving the car up and keeping the 0 %column close to zero as possible? I am trying to just learn whats up before the utec actually arrives!
i posted this at nasioc but hmm guess what nobody responded..surprise surprise! utec comes today!! wooT!
Read the UTEC Manual available for download from the TurboXS website. Also read the quick tune guide available from here:
http://www33.brinkster.com/ginge/
Set injector scaling to about 740 should work. Do not change the stock size. Get a wideband. Those injectors idle badly when cold. Do search on NASIOC, loads of threds on tuning these injectors.
thanks for the reply..i read ur utec tuning guide!!! very well put together. i am getting the utec today so i havent actually looked at the software yet...how exactly do you change the scaling???
RTFM... read the utec manual about 5 times.. it will answer all your HOW DO I BLAH questions..
and you can run an MBC in place of the ABC w/ the utec in which case you will not relly at all on the boost map within the utec settings.
1 - 4 of 4 Posts
