1 - 4 of 4 Posts
Is there anyway I can fix this? On a budget didn’t have money to rebuild. Jdm ej 20 was the cheapest.
Discussion Starter · #3 ·
Yes this is the code causing check engine light and I’m assuming throwing my car in limp mode. Trying to find a way to bypass this. Any ideas ?
Super Moderator
I just googled it. It has to do with the intake cam timing sensor. Either your ecu doesn't like the jdm one, it's a band sensor, low oil pressure, or timing belt installed incorrectly.
Considering the nature of jdm engines I would check the timing belt then the sensor.
1 - 4 of 4 Posts
