1 - 6 of 6 Posts
alright, i'm about to do my uppipe install and have seen a bunch of different versions of the instructions, some say i need to drain the coolant, some say don't, some say remove the exhaust, some dont. I need a solid set of directions. All im doing is a catless uppipe, nothing else.
Thanks guys
the way i did mine(also chaning out dp) was take out dp, unbolt uppipe, take out the passenger side engine mount bolt, jacked up the engine(for more room),had my g/f pull out the uppipe while i was under there trying to twist it out. its in there pretty tight
uppipe install problems
So, yesterday i went out and got an O2 socket and all the other tools needed, jacked up the car and went to work. I had the intercooler out, the heatshields off, the downpipe detached, then, finally i got to the uppipe and saw that the previous owner had already put in an aftermarket uppipe:mad:
bummer huh?
*smack*
ha! howd you miss that!??
lexington eh?
im up in lowell. sometimes skate down at that little crappy lexington skatepark with my street skating friends :rolleyes:
1 - 6 of 6 Posts
