2011 WRX 5 Door
Daily Driver. No tracking plans, just the occasional spirited driving like everyone else on here.
No other current suspension mods. I know tires will help but I'm just going to flatten the OEM tires before upgrading my summer tires.
I've read through a lot of the information I could find on upgrading sways but I still want to make sure I'm correct in my assumptions. I have a good deal on a lightly used Whiteline adjustable 22mm rear sway that I'm going to pick up shortly. I'm going to get the KB endlinks from TiC as well.
My understanding is that this will reduce the current understeer and body roll of the car, correct?
Would the experts suggest I start with the sway at the middle setting or just go straight to the stiffest setting and pair back if needed?
Anything else I should purchase while I'm back there like the ALK? Does it really increase NVH by that much?
Is adding 24mm front sway (OEM at 21mm?) a matter of personal preference for handling or is this what might be considered the "recommended" path? I guess my real question is will 3mm make much of a difference? If I do the front, I probably wouldn't for a little while just because I have to sneak these things by the wife. :wiggles:
Not sure if anyone has done the rear sway and later on done the front that could comment on experiences with both setups or not.
Sorry for all the questions. Suspension is not my forte. I've only ever made it through engine mods before I sold my last couple Subarus. Thanks in advance for any help/advice!
