1 - 11 of 11 Posts
TurboXs WRX UTEC Engine Management Stand Alone $650 OBO
Plug-&-Play
No cutting, splicing or additional sensors required
20 minute, do-it-yourself installation
End-user programmable via PC or PDA with HyperTerminal
Fine tune the maps for your exact setup
Pre-programmed base maps available from TurboXS get you started quickly and safely.
Five (5) maps plus stock mode selectable with a flick of the switch:
Create custom maps for street gas, race gas, nitrous, or whatever.
No need to lug around a laptop just to switch between your program. Optional remote swtich
Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites
Complete ignition timing control
Fuel control:
Controlled via MAF sensor signal offset Tune stock and larger than stock injector
Load reference:
MAP (manifold pressure)
Closed loop boost control programmable via Throttle Position and RPM
Knock control:
Automatically retards timing when the knock is detected safeguarding against engine damage
Adjustable knock threshold, timing correction, and duration
On board data logging
Built in programmable solenoid controller:
Control Nitrous, Water Injection, Intercooler Sprayer etc.
Drag racing launch control (secondary rev limit used during launch)
Free software upgrades.
all for 650/obo first one gets it. If you live nere Portland no shiping cost
I don't want to ruin your thread, but... 2 things:
1. the utec isn't really a stand alone (although it technically can be used as one).
2. it will be more than difficult to sell at that price. I've seen utecs sell for as little as $250. Typically they are $350 shipped nowadays.
Look on ebay 2 in the past week went for 625 and 598 but I am asking obo.I have seen a car worth 25000 go for 3000 but that doesn't mean I should sell mine for 3000 know what I mean? Also it is a standalone because it has the capabilities of working off line from any stock ecu. If you call turboXs they will also notify you of the abilities to run anything in a car that makes it a running vehicle which is the technical definition of a standalone ecu.
Discussion Starter #7
Bump
Ok I will sell it to the highest offer in the next 24hours if its 10 dollars then so be it.
175
Discussion Starter #11
ok well I had a buyer at 495 but he backed out so if nothing else I will sell it fri. to this guy for 200 done deal. And pease dot say you will do it if you don't have the cash.!! So any offers hit me up or call me 3609809669
1 - 11 of 11 Posts
