1 - 6 of 6 Posts
hey all. i am fairly new to turbo cars. i am looking to upgrade my stock turbo. i own a 2007 subaru wrx and i am fairly stock. i have a invidia turbo back exhaust with invidia cattless downpipe and a cobb accessport with a stage 2 tune. i am currently looking at buying the blouch 16g xt turbo. my question is what type of supporting parts/mods will i need to do to my motor to be able to use/ handle this turbo?
You will need to at least do the following:
Injectors
Fuel Pump
Tune
I would suggest going with 1 step colder spark plugs. Whats your power goal you're aiming with the 16G?
i would like to try to get into the 350 or higher range if possible. and what kind of spark plugs? i also read that i should go with an sti top mount.
If you're looking for 350+ AWHP, then you will need better cooling than an STI factory top mount and a larger turbo than the 16G.
How much are you looking to spend and when are you looking to do all this?
i was looking to buy parts as i got money and was wondering what all parts i would need to support a bigger turbo. what kind of turbo would you recommend to put me in the power im desired.
1 - 6 of 6 Posts
