Turbo Swap how do i do it
2810 Views 7 Replies 5 Participants Last post by  SD_GR
Iv got a new turbo for my 04 wrx and I don't know exactly how to change them out any tips would be helpful i plan to do this mod on my own/with a friend.
Also do i have to flush my coolant?
1 - 8 of 8 Posts
Well let's start here - Is it a stock TD04? Or did you pick up something aftermarket?
ok cool...should be a simple 1 to 1 swap then. You have no idea how many people come in here asking your same question, only to have some big ole GT35 rotated turbo thinking they can just slap it on without any supporting mods.
I've not changed a turbo myself, but I know it's pretty straight forward. The biggest pain is being able to get to all the bolts for the Uppipe and downpipe. Have ratchet extensions available. Obviously you have to pull the TMIC off...and be sure to take it easy on the oil feed line when removing it. I don't believe you have to flush the coolant, but you may have to burp the system since it's been opened up to air.
If you search Google, you'll likely get a how-to from NASIOC. They have tons of useful how-tos, just because its a much bigger site (just full of a lot more jerks :) )
Hey thanks man i appreciate the help.
My first thought was that he'd have to battle the Green Brackets of Death, but not so if he's just swapping in another TD04..whew. Been down that road!
PB Blaster is your friend. A knowledgeable person here (Trainrex) advised me, years ago, to get a can of it, soak the bolts that you'll be working with on the up and downpipes, and then let it sit overnight. Be warned that it smells to high heaven, if you're in a closed garage, as I was. I'm convinced that this was helpful to me, on my 2nd WRX, which had had a few years to gather some rust on the bolts.
http://www.clubwrx.net/forums/showthread.php?t=134356443
Sent from my SAMSUNG-SM-G890A using Tapatalk
Instead of PB Blaster, I really, oh really like AeroKroil. If you can find it, spring for it. I honestly believe it's a step above.
For band-aids I actually just buy store generic brands.
1 - 8 of 8 Posts
