1 - 4 of 4 Posts
Could someone recommend a turbo upgrade? I’ve spent some time doing my homework, but I’m still not sure what to get. Goal is 400-450hp. I’ve seen the Blouch’s, but there are a few variations. I’m just gonna copy and paste my setup from an old Craigslist add;
IAG stage 2 (tuff) short block
ARP head bolts
STI 12mm oil pump
Torque Solution pitch mount
Invidia catback exhaust
Tomei UEL(wrapped) header and up-pipe
Grimmspeed catted downpipe
Go Fast Bits hybrid BOV
KStech phenolic spacers
Cusco pulley kit
Kartboy short shifter and bushings
Cobb Accessport V3
Cosworth intake
ACT clutch
Process West Verticooler TMIC
Whiteline tie rods and ball joints
Godspeed lowering springs
Killer B high flow water pump housing
Perrin intake tube
1000cc injectors
AEM fuel pump
Killer B windage tray
Killer B pick up tube
STI oil pan
Defi boost gauge
AEM X-series wideband gauge
Steamspeed turbo blanket
GetADomTune coolant bypass mod
Autometer oil pressure gauge
Cobb boost solenoid
IAG AOS
Blouch Dominator Turbo
SMY gauge pod
JCS custom a-pillar pod
Mirimoto LED headlight kit
Mirimoto LED fog lights
IAG TGV delete
Air pump delete
255/40R17 Nitto NT05 tires
Sounds like a great set-up. I would use the blouch dominator 2.5 my car with similar set-up to yours makes 400 hp atw at 20 psi. Turbo and verticooler will support 24 psi and should get 450 or more hp atw. I am getting mine tuned in a couple of weeks after the 6 speed upgrade so I will know then.
1 - 4 of 4 Posts
