What would be ok to keep on it and what mode would yall recommend to just be able to use the cobb accessport
You could leave the turboback exhaust on it, replace the boost controller, the FMIC, BOV, CAI, headers, and injectors with all stock parts and run the stage two map with the AP (as long as there aren't any other modifications that you're not aware of). Of course buying all of those stock parts to swap back on to the car will cost a lot more than just getting a custom tune made for it. Not to mention you would be losing a lot of performance going back to all stock parts..
Also consider the fact that the maps that come with the AP are made to be a one size fits all solution and to be honest, they just aren't very good. Even if you only had the turboback exhaust on it I would still recommend getting a custom tune over running the Cobb map. A custom tune will make significantly more power, drive smoother, get better gas mileage, and be better for the engine than running one of the off the shelf maps.
Ok so i guess the best bet would to just take it to a pro tuner. We have one local here.
Just make sure you don't try to drive the car at all in the condition that it is in.. you will need to get it towed on a flatbed to the tuner. Or you could potentially get the tuner to email you a base map that would be safe enough to get the car from where it is to the shop to be tuned. But to do that you will need to be absolutely sure about exactly what parts it has on it so the tuner can make the appropriate map to limp the car to his shop, and I don't see that happening since ID doesn't even make 750cc injectors.
