1 - 6 of 6 Posts
The drain hoses for the window run down the side of the trunk inside the jack area. Is it disconnected or torn? That can mess with you sometimes. Also, +1 Donkey's idea. The bolts on the top of the inside of the trunk can leak. :p
Discussion Starter · #5 ·
bolts are sealed up top for the wing. i used rtv silicone sealer its for engins but what the hell i found the leak but idk how to seal it. down by the trunk latch on the car 3 inches to the right and the left there are factory pressed wholes and they are letting water in. i have no idea why they are just open wholes in my trunk. im gonna get some plugs and seal that.
Having same issue with water in the jack area. Had no idea about the window drain hoses I’ll be investigating if that’s possibly my issue thank you!
1 - 6 of 6 Posts
