1 - 20 of 20 Posts
I just changed my transmission fluid to Mobil 1 synthetic 75W90. I'm at 12,000 miles. Shifting has a much easier action now. I'm curious to see if I still have the spoon-in-treacle feel on cold mornings though. What's the general consensus on Mobil-1 synthetic for the WRX tranny?
What is everybody else using, and what are you observations. What mileage did you change at?
-Pace
I was thinking about changing mine very soon, too. You used Mobil 1, huh? hmm trying to decide between Mobil 1 and Redline. I'm at a little over 10,000 miles. Are you thinking about changing differential fluid, too?
Thinking Man's Engine
I've used Redline MT-90 in the past. Redline is generally well regarded for its gear oil. The MT-90 is formulated for synchro function. It shifts smooth as soft butter in the winter when the gearbox is still warm.
Depending on the source, it may cost less than Mobil 1 or more expensive.
Redline MT-90 would be the perfect gear oil....except...It is only GL-4 rated and our trannies require GL-5 oil.
Some people have used it anyway with no reported ill effects yet, but long term there could be issues.
Redline Superlight Shockproof is also supposed to be good, especially for hard shifting
What do you guys think about changing the tranny oil to the brand royal purple? i hear it's one of the best. also if i changed my tranny fluid, is it worth it to get a flush? or should i just drain it, and not worry about it? thanks for any input.
---RaCinWRX
I did some research and this is what I found so far from what some
rexer are using.
Mobil 1 Motor oil, No zine and pure than other syn according to the spec I found on a motor oil site.
Redline 75W90NS for tranny. It does not interfers with the syncron since it got less modifiers.
Redline 75W90 for the diff. Better lube properties with modifiers.
Hope this helps.
the mechanic at the dealer told me to get all diffs and tranny done at the same time, and Redline works great...he also said wait till i hit 30K miles before I change it.
From what I read.
Redline 75W90NS for tranny ( without modifier since sycrom doesn't like modifier ).
Redline 75W90 for the diff ( with modifier for less frictions).
Mobil 1 10w30.
Moderating on the run!
I considered Redline for my tranny and diff, but read too many conflicting reports on performance in the tranny. Some were even saying a mixture of NS and regular 75W90 in the tranny was needed.
Instead I went w/ Mobil 1 75W90 in both rear diff and tranny. That was at 10,000 miles last November. After a particuliarly long winter, I am comfortable in saying the Mobil 1 performed well. Shifting is smooth, even at below zero temps.
We'll see how it does through the rigors of a hot summer. So far so good.
Big Sky
here's a question:
somebody told me to flush the tranny line b4 i change tranny fluids. somebody else told me that it's like changing oil and i don't need to do a flush till some 80k miles or something. who's right??
--RaCinWRX
That I don't know (besides somewhere on the bottom of the transmission pan, and the fill plug is on the side). For oil, the manual may have it listed.
Get 5 quarts if you are also changing the filter.
Put 4 1/2 quarts in and top it off slowly. Rex does not like overfill, both engine and tranny.
I check mine when the car was cold and the tranny oil lvl was low. I went to the dealer thinking something is wrong and was told to check the tranny oil level when it is hot not cold.
When it is cold it shows low and high when it is hot. So if you fill the tranny to high when it is cold then it will have 2 much oil in the tranny, since tran oil expands as it get hot.
I am doing mine at 6000 with my second oil change. I will be using redline NS. As for motor oil I use Castro Syntech blend since I put in 120 miles a day I go thru oild change every quickly so Mobil 1 and fancy filter will be a waste. I check the oil at 5000 and it was still nice and clear not black.
Btw the subie tech told me I can use synthetic tranny oil if I like just make sure it is GL5 then it is cool with the dealer.
Redline Gear Oil
I've used Redline engine oil for over 10 years in everything I've owned and it absolutely rocks! On my old Porsche 914 Redline 75W90 synthetic gear oil worked very well and greatly improved shifting. On the other hand, based upon what I've heard, I would not recommend Redline gear oil for our cars. I just purchased Motul 300 synthetic oil that I plan to put it in tonight and have heard nothing but raves about it.
My $.02
quick update, I change gear oil every 5k miles, due to a lot of track events.
I tried royal purple, and it is the worst crap I have ever used. Its slightly smoother shifting (honda-esque) than redline, but still not as smooth as the OE oil.
Royal Purple completely breaks down at track temps, usually after about 10 minutes on track every single 3-4 shift grinds.
Now I am using 1 qt Redline lightweight shockproof and 2.8 qts 75w90NS. Holds up very nicely on track, shifts great although a little notchier around town.
If you dont go to the track then I would recommend the OE fluid. My friends WRX with stock gear oil shifts much smoother than mine.
and btw-- whoever mentioned 4.5 qts is getting gear/transmission oil confused with engine oil. The tranny takes 3.7 qt and doesnt have a filter
Re: Redline Gear Oil
My $.02
I've also heard good things about some of the "other" fluids by Motul (I use their brake fluid). Where are you sourcing Motul gear oil?
Thanks
Big Sky
Re: Re: Redline Gear Oil
Thanks
Big Sky
I got my Motul Gear 300 gear oil from Pantera Intl. @ http://www.motorspot.com/index.html
I put it in over weekend, drove 300 miles or so and so far it definitely shifts smoother and I'm getting less of the obnoxious bearing noise I've been experiencing.:p
1 - 20 of 20 Posts
