1 - 3 of 3 Posts
Hello,
I have a SUBARU WRX 2016 2.0 CVT.
Does it have a transmission cooler? If yes, is it located in front of the radiator?
I had an accident and I bought a SUBARU STI 2016 nose cut.
Since the STI have a manual transmission I am not sure if my WRX need a transmission cooler.
Also, The STI radiator seems to have 4 hoses while my WRX only require 2.
Is there any way to make it work?
Super Moderator
I wouldn't rig anything together. I would buy the correct hardware like radiator. I do believe the CVT has a transmission cooler although I'm not sure of it's location.
Look at the stock radiator. The fins on the radiator will be slightly different than the transmission cooler if it has one. The only example I can give is my 16 Colorado: the stock transmission cooler is on top of the radiator and has one small diameter metal tube going in one side and out the other back to the transmission. The radiator is below the cooler.
1 - 3 of 3 Posts
