1 - 4 of 4 Posts
Hello, i'm quite new here and I too have had transmission problems. I am in the process of getting a new transmission on my 05 wrx. Are there are any mods I can put in the transmission to make it stronger?
Or is getting a brand new transmission the only answer. Much thanks.
if you put ppg gears in the old tranny and the old tranny still dies on you, is it likely that the gears will be salvagable for resale or garbage?
The Default One
That would depend on if there is any damage to the PPG gears. It's hard to say.
Most of the time when a Transmission dies its due to gear failure, by way of too much Torque. However failure of PPG gears is not very common, as you may have read in other posts.
Another common problem (albeit less common) is Syncro (sp?) failure. In this case you just need a new Syncro.
1 - 4 of 4 Posts
