1 - 11 of 11 Posts
I have a 2015 WRX which I think has a problem. I drive on a winding mountain road every day. When I accelerate through a tight turn the entire car shudders or hops sideways. It has always done this since I bought it new. Is this normal? BTW - I'm not referring to the clunking that occurs when I have the steering wheel full lock while maneuvering in my driveway.
If this is not normal what are the most likely causes? Center differential torque bind? Bad juju?
Any ideas?
Super Moderator
Something is wrong. Could be front middle or read diff
Æternum
This doesn't sound normal, though I will say that when the fluids are very cold, I get a slight amount of bind when turning at low speed and high steering lock.
Is there a possibility that you are feeling the Active Torque Vectoring? Try disabling that ATV (hold TCS button until light illuminates the dash) and see if you still experience the issue.
Æternum
I thought there was no middle (center) diff on the 15+ wrx? I thought only the sti had one
It's continuous AWD. How would you expect it to operate without a differential?
EDIT: I feel bad for making a joke at the OP's expense, but I guess the answer would be "sorta like OP's car!" :wiggles:
I know there's a front and rear differential and I've changed the oil in them a few times already. I just wasn't sure what a "middle" differential referred to.
Super Moderator
Isn't the front diff lubricated by the transmission fluid and not a separate entity?
Super Moderator
correct, I used motul gear 300 non LS
So you've changed the gearbox oil and the rear diff.
Op. Have you tried the traction control suggestion yet. I hadn't considered that being a possibility.
Æternum
Yes, as is the center diff.
It's a mechanically simple setup and despite all the shortcomings of Subaru's "symmetrical AWD," at the very least it's simple and robust.
1 - 11 of 11 Posts
