Is it possible to make a WRX have toggle able AWD (you can switch from AWD to RWD). Has anyone done that?
Why couldn't you just shut the solenoid off?No, it's not possible.
Well, certainly not within a reasonable budget.
Sent from my SAMSUNG-SM-G890A using Tapatalk
It doesn't work like that.Why couldn't you just shut the solenoid off?
I've read you can weld the center diff, and it would make your car a RWD car. Is there any risks with that? If not you could just buy a stock center diff, weld it, and when you want rear wheel drive, switch it with your stock diff.It doesn't work like that.
I thought it would be good for drifting, because then you wouldn't have such a hard time loosing traction.It's going to mess the tempering up on anything that gets hot making it weaker and likely more brittle. You would also have to remove the front diff, the driveshaft, and the half shafts. It's about the most ghetto mod you could do, people used to do it all the time in jeeps and the diff's failed a lot.
I mean you could do that but I doubt that much effort would be woth wasting time. It's not a minor undertaking. I know a guy who has a welded diff in his race car to lock it, it works, for now.
You are a ridiculous person.
Read my damn post.
You wouldn't have enough control. The mistake with drifting is "losing traction" you still have traction, if you lost it your rear end would just flail around wildly.I thought it would be good for drifting, because then you wouldn't have such a hard time loosing traction.
Drifting is controlling the loss of traction. Your rear wheels don't have traction. Your using the momentum, and weight of the car. You also use your front tires as guides. That's why I don't like AWD drifting, it's not drifting, it's power sliding.You wouldn't have enough control. The mistake with drifting is "losing traction" you still have traction, if you lost it your rear end would just flail around wildly.
