1 - 12 of 12 Posts
I did a little research for the tire weight because I'm going to purchase a new set of wheels (decided on SSR Comps in 17x7.5) and I'm trying to decide on a tire to go with them.
I decided to compare the Bridgestone S03, Toyo T1-S, Falken Azenis Sport, and Kumho Ecsta 712. Here is what I found for the tire size 225/45_17.
T1-S - 20.9 lbs
S03 - 25 lbs
Ecsta 712 - 25.2 lbs
Azenis Sport - 25.9 lbs
Wow, 4 lbs difference per tire for the T1-S as comapred to the S03!
Although my WRX is driven mostly on the street, I am performance minded and feel the T1-S may be my choice because of the low weight and its overall good dry/wet performance. These are not going to be Winter tires - I'll be taking them off for foul weather (snow). The S03 is a close runner up and I still have not decided 100%. I've driven on S03's (not in a WRX) and I know they're great - they stick and they are quiet.
Has anyone out there tried both the S03 and the T1-S?
Any comments on the T1-S?
Thanks! - gene
I had the T1S's and they are fantastic tire. The S-03 may have a small advantage on dry pavement but they are a bit oversized which may cause rubbing issues. Also, the weight. Advan AVS Sports and T1S's were both QUITE a bit lighter than the S-03's and both have performed VERY well for me.
The AVS Sports(Yokohama/Advan) are also quite stiff sidewall(compared to S03). Another thing to keep in mind is not necessarily a performance issue of tyres, but rather the feel. Sure you can have a tyre that grips like mad, but it can also lack in communication....and this is where tyres can be "considered" a personal preference. The more confidence you have, the better you perform.
Discussion Starter · #4 ·
Thanks for the comments.
Hmm, I was not aware the AVS Sport was lighter than the S03 - could not find weight specs on Yokohama's site.
O.K. - for those of you who have had T1-S's:
"at the limit" how is the feedback?
also, will they survive the big potholes of philadelphia and south jersey area (wondering if lighter=weaker)?
-thanks!!, gene
2BARjones said:
T1-S - 20.9 lbs
S03 - 25 lbs
gene
Good info, gene! I feel like T1-S is a very good choice. I have a wagon, so I need 215-45-17 and they do have this size. Hey, when you buy 5 lb lighter wheels price changes from around
200$ to 600$ a rim, so it is better to choose a lighter tire. Where did you find this info? I wanted to check a few other tires.
Vlad
Discussion Starter · #6 ·
where to find the info
To find the tire weight, try going to the mfg's website and locate the specs section for the tire you want. Unfortunately, I cannot find the weight for the Yoko's (AVS Sport) - maybe someone out there has it?
-gene
Moderating on the run!
I've got the T1S in 225/50/16 wrapped around Volk TE37's, this makes for an extremely light combo. The T1S gives up dry handling to only two tires (excluding R-compunds ofcourse) that I know of- the KD and the Azeni. Ofcourse the T1S outperforms them in the wet by a wide margin. I've run over a dozen autox's and a two day driving school with them and am thoroughly impressed with their dry performance under stressful conditions. I've also been through some monsoonal rain storms and even a couple of freak snow storms- they performed wonderfully (do not adovocate these a s a winter tire-just pointing out the performance).
As you've discovered they are light, but also stiff sidewalled and appear to wearing great. They are not cheap, but no hi po tire is.
Gene,
I'm looking forward to trying them, but I with S.
I am a YOKO fan now. BIG TIME!
-Jim
Discussion Starter · #11 ·
thanks for the comments Big Sky - wow your tire/wheel combo must be very light weight! - is that a daily driver set-up or is it for the tracks and auto-x's?
Plat, you should look into R-compounds!! - you will need it to harness the "power of platinum"!! (lol)
BTW - thanks for letting me drive your car last night - very nice!!!
My wife's daily driver- my weekend autox/ track/ gravel (change of wheels/tires) plaything.
1 - 12 of 12 Posts
