1 - 2 of 2 Posts
I am going to order a Perrin Dp from World One pretty soon and am wondering what other things I need to order to make the install easier like gaskets and such. Also do you guys have any tips for the install.
Definitely need to get gaskets. Have some wd-40 around... if you can, work on the car after letting it cool over night. Put the wd-40 on the night before on all the pertinent nuts/bolts to make things easier in the morning. When stuff is cold this is a real easy install... when it's hot, it's 10x harder.
Undo the top bolts on the downpipe/turbo first. Then jack up the car, do the rest of the DP/turbo bolts. Then do the midpipe/resonator pipe bolts and just slide the whole thing right out. If you're havine trouble getting it out, loosen the midpipe/DP bolts to give you a bit of wiggle room. Without problems the whole install should take an hour or less. Have fun :)
1 - 2 of 2 Posts
