1 - 6 of 6 Posts
running a search for the terms "choke" i couldnt find much. when i blip the throttle on an upshift under normal driving rpms, the throttle seems to "choke." it literally sounds like someone is being choked and the car hesistates slightly then recovers. ive checked all my throttle cables and any external clues as to why this might be happening.
external engine mods are
perrin short ram
full turboback
turboxs upipe
I am going out on a limb here but air filter clogged. I would start there. If that doesn't pan out then probably a sensor.
Most Intakes seem to do more harm than good. Instead of an Intake i would recomend the stock intake with the silencer delete, a K&N drop in filter, a new silicon MAF hose and a Turbo inlet hose.
just my 2cents.
-J
yea i never really thought that it might be an actual intake problem. i was thinking more along the lines of a fuel problem but intake might be a factor. ill slap the stocker back on asap as long as i can find it see how it goes.
1 - 6 of 6 Posts
