why not just springs?
so just bought some TSW Nurburgring wheels in a 18x9.5 +40mm for my car (2017 wrx). It desperately needs to be lowered. I was looking at Bilstien B16 (PSS10) and they seem like a good choice. Just wanted some other opinions before i really get serious about buying a coil over setup.
I do not understand this logic.I'd rather not mix and match OEM parts with after market parts in terms of my suspension setup
That is not really an option with either.its just my preference. If i want it lower or higher I'll be able to adjust it accordingly as opposed to a fixed spring height. p
Make sure the lock rings are drilled for a set screw or locking. They tend to loosen. Some guys buy extra lock rings to ensure they stay level.its just my preference. If i want it lower or higher I'll be able to adjust it accordingly as opposed to a fixed spring height. p
i havent heard anyhting bad about Subispeed but those coils are also on tirerack.com but it says 2012 WRX. do you think they will fit?
