Hey guys I got an 02 WRX and its been puking coolant lately out of the upper rad hose. I found a crack in the hose and replaced it. In doing this i noticed the fans arent turning on and when i fill the coolant it acts like the thermostat isn't opening ie it never burps ive got a new t-stat, to replace the old one its on the bottom of the block right. Also when its doing this the temp gauge never goes above normal temp. I've checked the fuses the relays and theyre all good but the fans don't ever come on. I was looking at autozones parts when i got my t-stat and it says they have a part for a fan t-stat could that be bad or should i replace the block t-stat and see if that causes the fans to come on first and then replace the fan t-stat if not. if that turns up to be the prob where is the fan t-stat located. Thanks
