1 - 5 of 5 Posts
i have an '04 wrx and im planning on a tranny rebuild and need some help. i want stronger gears with a slightly shorter ratio in 2nd, 3rd, 4th and 5th but a higher ratio in first. ive read other threads about the kaaz kit which sounds good and am wondering if this kit makes it possible to downshift into first while moving above 5mph like (thats what my car allows). what other kits should i look into?
Kaaz are strong, but noisey !
Downshifting should be easier with this geraset, and with the sti / sti ra gearset..
On stock gearset with correctly preformed doubleclutching and revmaching I downshift into first from 18mph.. Usually I downshift to first @ 13mph. without any grinding or problems what so ever.
Do a search and you'll find more info about gearset's
STi gearset or the STi Ra, 1st is a bit longer and then every gear thereafter is a little shorter and they're rated for more hp then stock, the figures seem to be around the 345 whp mark.
Check out these guys www.rallyspec.com . They sell the Kaaz and the RA gears,,, the RA gears also can keep the regular 5 gear which will give you a good highway driveability
1 - 5 of 5 Posts
