1 - 4 of 4 Posts
Mods I have: K&N air filter and 3/16".
Mods coming: Uppipe, Kart boy shifter bushings, Turbo XS MBC (the cheap one) and a Blitz dual TT w/boost gauge ect.
I've read that leaning the turbo out (the fuel mixture I am guessing) can be very, very bad. What other mods can I do before I have to buy the $700 ECU piggyback unit? Would a downpipe be ok? How do I know when it is to lean and I am in danger of damaging the engine?
As always your help is appriciated.
Pete
"leaning out the turbo" is really leaning out the air/fuel mixture.
Stoichiometric ratio is 14.5 or 14.7:1 Air:Fuel. That's 14.7 "parts" of air to 1 "part" of fuel. Be it grams, ounces, etc, the chemical reaction is 14.7 parts to 1 to run to completion (nothing of either air nor fuel left).
Now, back in reality. Complete combustion NEVER occurs. It's impossible because we are not combining these things in a vacuum.
"Lean" means a ratio HIGHER than 14.7:1, i.e. too much air
"Rich" means a ratio LOWER than 14.7:1, i.e. too much fuel
Our cars run rich from the factory, as do most turbo cars. Running rich robs power, but because of the high possibility of pre-ignition in our cars, it's worth it. Extra fuel helps cool the explosion and keeps the engine running :)
You can run a turbo-back exhaust without anything else and not run lean. I would suggest purchasing several gauges (boost, EGT, Air/Fuel) or a DeltaDash if you haven't already.
1 - 4 of 4 Posts
