1 - 15 of 15 Posts
SuperNova
What brake fluid are you all runnin?
I have run the stock stuff and the Motul RBF 600.
I have run the ATE Super blue before.
I'm going to be changing brakes and fluid this weekend and was curious if anyone was using the Synthetic Castrol brake fluid? It is way cheaper than the RBF 600, and has a dry boiling point of 500 deg F.
FWIW for those who don't know, it is good to run the higher boiling point brake fluids on your performance car because:
* Brake fluid is hygroscopic meaning it absorbs moisture. The more moisture it absorbs, the lower the boiling point becomes.
I run ATE Super Blue
I need to do my brakes soon too...argh...I'm thinking about a BBK though. I need new fluid.
I use the Castrol mentioned but I don't tax my system so can't speak as to boiling point. I change fluids on schedule so I can't really tell how hygroscopic it is.
I use the ATE Super Blue. No issues.
What BBK are you thinking of?
¯\_(ツ)_/¯
ATE Superblue. Just DD usage mostly, and one autoX day. No brake fade ever, but then again, I'm not putting prolonged stress on the system either. Relatively cheap, and no complaints so far.
IF I decide to go with it, probably Wilwoods.
Awesome choice. Have you grinded the rear dust shields off yet?
I have not.
The best tool is a chisel bit on an air impact wrench. Just hit the spot welds and you'll have it off in 5 minutes.
1 - 15 of 15 Posts
