1 - 20 of 257 Posts
I have decided to contribute to my useless existence on the forum by compiling some of the stuff I found out there,including from other forums,that might me helpful to the many new 2011 & 2012 owners/members of the forum.
You can find almost anything about mods on this famous thread from another forum.Thank you Mr. Unabomber http://forums.nasioc.com/forums/showthread.php?t=533787&highlight=manifesto
For anybody who needs the service manual (thank you Mangostick) http://www.daviswoody.com/2009SubaruImprezaServiceManual.pdf
Some common questions that already have threads
Mileage thread http://www.clubwrx.net/forums/every...ilage-you-actually-getting-your-2011-wrx.html
Please feel free to contribute.
***Disclaimer:I am not responsible for anything you break on your car or any warranty claim denials
Discussion Starter · #2 · (Edited)
Most owners start out with a tint.You can find the legal tint laws for your state here
http://www.tintlaws.com/
Some do a clear bra.This is done preferably by a qualified installer as it is not an easy job.There are different kits & the price depends on how much of the car you want to cover.
Discussion Starter · #3 · (Edited)
the other popular mod is the short shifter & bushings.There are various types of shifters available on the market.You can also get a SPT short shifter installed by the dealer(the SPT shifter comes with the linkages).Another popular brand is kartboy.
It is advisable to change the bushings along with the shifter to improve overall shifting feel.
The entire kit with the kartboy shifter can be found here TiC 08 Impreza Super Shifter Set
It is a pretty straight forward install.
Written installations
http://www.twmperformance.com/manuals/2008-wrx-short-shifter-install-manual.pdf
Not included in the video is the install of the linkage bushings.
The instructions for the bushing install can be found on this sticky by EJ257.(Thank you Matt).The install instructions are for earlier models but they are the same for all 08+ as well.Also all bushing install can be found on this same sticky.
http://www.clubwrx.net/forums/transmission-awd/134325326-driveline-mounts-bushings-faq.html
This is a diagram of what you will be installing
A: Shift Linkage Bushings
B: Short Throw Shifter
C: Pivot Bushings
D: Front Shifter Stay Bushing
E: Rear Shifter Stay Bushing
Thank you sjcurtis & BlueAngelWrx for the video.
Discussion Starter · #4 · (Edited)
Another popular mod that brings about a love hate response is the Rally Armor mudflap.There is a less expensive variant also available called the Flapatax Mudflaps
When you order the Rally Armor mudflaps be specific about your model year & whether it is a hatch/sedan as the mounting hardware is different.
Included is a video of the install .The video is for a sedan.The instructions are the same for the front of a sedan/hatch but is different when it comes to the rear.
Discussion Starter · #6 · (Edited)
Discussion Starter · #7 · (Edited)
Discussion Starter · #8 · (Edited)
A way to seriously enhance your vehicle's cornering ability & to reduce body roll would be to change the factory sway bars to after market ones.There are many makes on the market including Whiteline,Perrin,Eibach,etc.
Install instructions for the whiteline swaybars
Video
Pictorial instructions for Rear sway bar
Discussion Starter · #9 · (Edited)
Along with the swaybars you can add aftermarket solid endlinks as the factory endlinks are not strong enough for forces that will be exerted by the aftermarket sways.Again endlinks come for different makers,the same that make the swaybars.You can mix & match the sways & endlinks.
Endlink install instructions.
http://peatpics.com/gallery2/main.php?g2_itemId=104973
Torque specs for the rear suspension
Something that I noted when installing whiteline sways & kartboy endlinks was that the spacers supplied with the endlinks were not enough to hold them perpendicular,so I had to order a separate set of spacers
http://www.rallysportdirect.com/Kartboy-KB-017WLS-Whiteline-Front-Swaybar-Spacers
You can also alternatively use washers from your local hardware store.
Pro Manscaper
Great idea for a thread IMO.
Perhaps for the Everyday Impreza Talk?
Discussion Starter · #12 · (Edited)
A popular mod for all WRX/STIs is the Hella Horn install.
For this you will have to remove the front bumper.Not a big deal,takes just a couple of minutes
Written instructions with pics
http://www.iwsti.com/forums/how-install/132142-2008-sti-front-bumper-removal.html
Video of bumper & grill removal
the simplest wiring diagram I found
You can use the bracket supplied with the horn or if you want them to stick out more & be more visible you can get a bracket http://www.subimods.com/subimods-com-hella-supertone-horns-bracket.html
I just got a steel bracket from Home Depot & painted it black.You can just screw the bolt into the hole on the right,but you will have to use a bolt with nut on the left(be extremely careful & use some guard if you tap the hole so as to not put a hole in the ac condenser)
You can also make a custom harness or order one from http://www.subimods.com/subimods-hella-horn-harness-kit.html
It is advisable to solder all your connections,heat shrink your butt connectors & apply dielectric grease.See that the fuse is as close to the (+) of the battery as possible.And please DO NOT HAVE SOMEONE HONK THE HORN TO TEST IT WHILE YOU ARE STANDING IN FRONT OF THE CAR.118db is loud.
Discussion Starter · #13 · (Edited)
COBB AP for 2011 WRX http://www.cobbtuning.com/products/?id=5611
COBB AP for 2011 STI http://www.cobbtuning.com/products/?id=5240
Review of the Cobb Accessport by ScoobyDoo12(thank you)
http://www.clubwrx.net/forums/tuning-electronic-engine-management/134345133-2011-sti-review-cobb-accessport-stage-1-a.html
Review of the Cobb SF Intake by ScoobyDoo12
http://www.clubwrx.net/forums/engine-modifications/134345159-2011-sedan-cobb-tuning-sf-intake-airbox-stage-1-sf-tune-review-pics-vids.html
Video of the Cobb SF intake on a 2011 STI
on a 2011 wrx
from one of our members,thanks mike
Discussion Starter · #14 · (Edited)
Discussion Starter · #15 · (Edited)
Discussion Starter · #16 · (Edited)
Discussion Starter · #18 · (Edited)
Discussion Starter · #20 · (Edited)
If your car did not come with fog lights you can easily install them since the car is prewired.The kit can be purchased https://www.subarugenuineparts.com/product_info.php?products_id=1732
The install involves taking off the bumper(you can find the instructions on how to take off your bumper in the hella post),replacing the stalk ,and mounting & connecting the fog assembly & replacing the front surrounds.All of this is included in the kit.You can also do the install without taking off the bumper by removing the side vent(as described below in "How to level your fogs") but this is a little tougher as you will not be able to see what you are doing.
The instructions are not very helpful.The toughest part is taking off the steering column cover to install the stalk..Just remember that all screws are installed in the down>upward position ,so they are accessed from under the steering.Also you do not have to rip apart the dash trim like the instructions state.To plug in the relay just remove the fuse panel cover just towards the lower left of the steering & shine a flashlight to you right & you will see the relays.
DIY write up by our own Subaken http://www.clubwrx.net/forums/exter...-2011-2012-wrx-sti-oem-fog-light-install.html
Most cars come from the factory with the fog lights leveled wrong.
2011 sti fog light - Height adjustable? - Subaru Impreza WRX STI Forums: IWSTI.com
Principle of leveling your fog lights
Daniel Stern Lighting Consultancy and Supply
1 - 20 of 257 Posts
