SD_GR said:
Front go zero toe, -1.3 camber, Kayabas and a 24mm bar on stock springs.
Did you actually upgrade the front swaybar?
SD_GR said:
Low cost and the car behaves correctly (only mild understeer is correct-- if you're not Alain Prost any counterpoint is moot...). It's not nosey and it won't unglue if you lift off, and at the limit it goes strait -- the safest option. Braking is not notably affected by the camber either.
The additional camber and the upgraded front bar should help dial out a bunch of understeer.
If you want to increase your handling, the FIRST thing you should do is address your tires, as they are the only part of the vehicle that touches the pavement, and they are the first weakpoint.
If your tires are good, and you're still having an issue with handling, the next thing you should address is the alignment. OE alignment specs suck from a performance standpoint, and a set of $30 camber bolts (R) and a custom alignment will go a long way, due to the way a McPherson strut operates). The camber bolts and custom alignment will be required for any modifications to the struts/springs, so seeing if spending $100-150 will save you hundreds in upgrades is a good investment, in my book.
That said, for the older WRXs, if you have to replace suspension (e.g., struts are end-of-life), there are three setups that I recommend, based on budget...
Wallet friendly...
Struts: KYB GR-2 / Excel-G
Springs: STI take-offs (should be able to find them on the cheap from someone looking to recoup some garage space)
Tophats: New OE F/R
Bumpstops: New
Alignment: Camber bolts for the rear to adjust camber. Max out front negative camber, reduce rear to be ~.5° less negative than up front (-1.3°F/-.8°R, -1.5°F/-1.0°R)
Middle ground...
Springs: Swift Sport
Tophats: Whiteline Com-C (F) / New OE (R)
Bumpstops: New
Alignment: Camber bolts for the rear to adjust camber. -1.5°F / -1.0°R
Street warrior...
Struts: Koni Yellow
Springs: RCE Black / RCE Yellow / Swift Spec-R (look at spring rates / lowering amount and decide which would be best for your needs, but all would pair well with the adjustable Konis)
Tophats: Whiteline Com-C (F) / Group-N or New OE (R)
Bumpstops: New
If you're still not happy with the setup above, look into the Whiteline ALK / RCA kits to pair with whatever strut and spring setup you chose. You'll need a new alignment after installation, target the same specs as above.
If you're still not happy with the handling, you can look into swaybar / endlink upgrades. Rough-correction for body roll should be done with the struts/springs, and fine-tuning should be done with the swaybars. I always recommend solid bars (vs hollow), and I always recommend adjustable. While a swaybar/endlink install doesn't change your alignment specs, you may need to re-evaluate the specs that you're running; because of the reduced body roll, you may require less negative camber to achieve maximum contact patch in a corner.
