1 - 20 of 23 Posts
I just got some new (used) STi stock tires (RE00486282689568725689whateverthehell) and wanted to know what tire pressures you guys use. Right now I think I'm at 32 all around.
P.S. So much queiter than Azenis!!
I've always run about halfway between the manufacturer's specs (placard on driver's side doorframe) and the max pressure printed on the sidewall for the tire.
40 front 35 rear. For AutoX 45 front 40 rear. Next race I'm going to play around with tire pressures just a touch. Maybe 48 front and 43 rear.
that 5 pound differential really helps the car stay balanced.
-Ryan
Right now I run 38/38..... So does running a slightly lower pressure in the rear help rotate the rear around better? Or visa-versa?
The way I understand it (I could be wrong) is that a lower pressure in the rear than in the front reduces oversteering while an even front/rear tire pressure increases oversteering.
The front is supposed to be higher pressure because of the extra weight from the engine. This makes the car more neutral.
Ok.... So since I want my car to oversteer more and understeer less, an even f/r pressure setting should be good then. Right? Can anyone else confirm?
That will be fine Cam. Assuming a street tire, the increased pressure is slightly decreasing the contact patch, and usually shortening the breakaway time. This is all different for different tire constructions.
Most people run a few lbs less in the rear because of the weight difference and apparently, helps with the decel noise.
Don't worry about it.
Yeah, I wouldn't worry about it to much. My car still oversteers like mad with the 5 pound differential. I rotates very nicely with very neutral feel, if the tires were equal pressure it would be way to much.
-Ryan
1 - 20 of 23 Posts
