1 - 10 of 10 Posts
My friend just got an 04 WRX, which I have as well. I drove his car today, and it felt 100% different than mine. He has a regular shift, and I have a short throw shift.
His shifting is much more smooth than mine (putting the shift knob into position), and his clutch is a lot more "pillowy..or cushioned" than mine. And a lot easier to push down. Is this the difference between the two, or is my car just wierd. Its the only other wrx I have driven, so I dont know what to compare to. But his car does feel much different. I'm confused.
I drove Josh's car (Colorado Rexer) and his clutch felt way smoother than mine. I think it might have something to do with the clutch shift point. From what I've read, the shift point is not the same on all rex's off the production line, but it is adjustable. My clutch likes to "pop" out at a certain point, which makes it more difficult to control the shift.
Josh's car also felt much different than mine, but that might be the VF34, catless exhaust, and accessport distorting my perception a bit. :tongue:
Re: Re: tech: short throw shift compared to regular.
I love my baby Rex :)
As for the short shifter....I have the Perrin Short Shift Adapter so I still have all the original shift linkage setup, jest an adapter to shorten the throw. I love the feel. Very easy and crisp.
If he has a new 04, then maybe the clutch difference is just because its a new car.
i have the STi SS, and it is more notchy than the stock shifter/linkage. But its worth it. Me likey.
P.S. IBTM
P.S. IBTM
i have the same SS in my 96 impreza LX and i love it :wiggles:
When I used to work at the dealership it always seemed that the 04 clutches engaged much later... (which was somewhat dangerous while trying to park 4 cars in an area meant for 3) But anywho, I wouldn't worry about it.
A bit offtopic maybe, but I would perfer the stock shifter because it's longer.
A shortshifter would enable you to shift faster and meaning you will throw the car in gear faster and that would mean easier to breake your tranny..
Sicking to the stock shifter lenght feels like a safety device to me ;) I also have the shifter higher up and closer to the steeringwheel, i doubt you will earn much by changing the shifter.
Shorter shift throw & longer hand movment = short hand movment & longer shift throw:p
but It looks way better with a shortshifter :tongue:
1 - 10 of 10 Posts
