1 - 14 of 14 Posts
That light is controlled by a contactor on the e-brake handle, try to wiggle it back and fourth to see if you can get the light to flash. or just take the console apart.
Its got nothing to do with the brakes, transmission, etc.. It's just a light to let you know that your E-Brake is on like the handle pulled up is not a dead give away.
I'd say 90% sure it's the fluid, what your describing with the on/off with stoping and going is the exact same thing I had happen.
Check continuity with ground on both the red and black wires in that connector that plugs into the brake resivore. The switch basically either grounds the bulb in the dash whenever a) fluid is low b) the handle is pulled. There should be 0 continuity with the handle all the way dis-engaged.
1 - 14 of 14 Posts
