1 - 15 of 15 Posts
Ok now that I have a "weak" single port wastegate of about 12psi (spring only) I am able to control boost and get some taper but it's not too bad all-in-all. I will just let the datalogs do the talking. Now keep in mind I am using the sea level calibration of the MAP sensor so the boost numbers you see are actual sea level equivalent boost levels (IE: to get boost gauge readings up here add about 3.5psi to the numbers you see to get an idea of the relative amount of boost I am running at 6000ft. above sea level). ALSO keep in mind that I saw about 500-600 engine rpm LESS lag at sea level on my VF22 so this 18G should see a similar effect.
The first log is just of a roll on in 3rd gear on level ground. I stopped where I did becuase I fit fuel cut :). As you can see I hit a peak boost value of about 19.6psi which means my boost gauge was showing about 22-23psi and my AVC-R reported 1.55-1.60 kg/cm2.
rpm map maf tps load knock afr ign1 inj1 mign mfuel mmaf
2380 -9.1 2.0 5 00 00 14.5 +33.0 5.0 ECU. -7.0 ECU. 1.8
2403 -9.1 2.0 5 00 00 14.6 +33.3 5.0 ECU. -7.0 ECU. 1.8
2392 -9.1 2.0 6 00 00 14.7 +33.3 5.0 ECU. -7.0 ECU. 1.9
2431 -8.1 2.3 15 00 00 rich +39.4 7.0 ECU. -7.0 ECU. 2.1
2422 -6.1 2.3 15 00 00 15.8 +36.9 8.0 ECU. -7.0 ECU. 2.3
2482 -4.3 2.4 68 00 00 12.6 +36.6 8.0 ECU. -5.3 ECU. 2.4
2506 -2.8 2.6 99 10 00 12.1 +35.1 12.0 ECU. -5.3 95.00 2.4
2521 -2.4 2.6 98 10 00 rich +34.1 13.0 ECU. -5.3 95.00 2.4
2562 -2.2 2.5 98 10 00 rich +33.7 13.0 ECU. -5.3 95.00 2.4
2610 -1.6 2.6 98 10 00 rich +33.5 14.0 ECU. -5.3 95.00 2.4
2675 -1.2 2.6 98 10 00 rich +33.3 14.0 ECU. -5.3 95.00 2.5
2699 -1.0 2.7 99 10 00 rich +32.9 15.0 ECU. -5.3 95.00 2.6
2757 -0.8 2.7 99 10 00 rich +32.2 16.0 ECU. -4.9 95.00 2.6
2794 -0.4 2.7 98 10 00 rich +30.5 17.0 ECU. -4.9 95.00 2.6
2822 +0.2 2.8 98 10 00 rich +30.5 18.0 ECU. -4.9 95.00 2.7
2871 +0.8 2.8 98 10 00 rich +30.2 18.0 ECU. -4.9 95.00 2.7
2926 +1.3 2.9 98 10 00 rich +29.2 19.0 ECU. -4.9 95.00 2.7
2957 +1.7 2.9 98 10 00 rich +28.5 20.0 ECU. -4.9 95.00 2.8
3005 +2.3 3.0 98 20 00 rich +27.1 22.0 ECU. -4.5 66.00 2.8
3075 +2.7 3.0 98 20 00 rich +26.4 23.0 ECU. -4.5 66.00 2.9
3121 +3.1 3.0 98 20 00 rich +26.0 23.0 ECU. -4.5 66.00 2.9
3198 +3.7 3.1 98 20 00 rich +24.6 25.0 ECU. -4.5 66.00 3.0
3261 +4.3 3.2 98 30 00 rich +23.8 26.0 ECU. -3.8 45.90 3.0
3267 +4.7 3.2 98 30 00 rich +23.1 29.0 ECU. -3.8 45.90 3.1
3380 +5.3 3.3 99 30 00 rich +20.8 32.0 ECU. -3.8 45.90 3.2
3443 +7.0 3.4 98 40 00 rich +21.4 33.0 ECU. -5.6 45.90 3.3
3546 +8.6 3.5 98 50 00 rich +19.2 36.0 +17.0 -5.6 45.50 3.4
3619 +10.6 3.7 98 60 00 rich +16.4 43.0 +17.0 -5.6 45.50 3.5
3687 +12.7 3.8 98 70 00 rich +14.6 52.0 +16.0 -5.6 45.50 3.6
3732 +14.3 3.8 98 80 00 rich +14.1 56.0 +16.0 -6.4 43.60 3.7
3903 +15.7 3.9 98 80 00 rich +13.8 59.0 +16.0 -6.4 43.60 3.7
3996 +17.6 4.0 98 90 00 rich +14.5 61.0 +15.0 -6.4 43.60 3.7
4070 +18.8 4.0 98 100 00 rich +15.1 62.0 +14.0 -7.2 43.60 3.7
4151 +19.0 4.0 98 100 00 rich +15.5 64.0 +14.0 -7.2 43.60 3.7
4230 +19.2 4.0 97 100 00 rich +14.3 63.0 +16.0 -8.2 44.90 3.7
4345 +19.6 4.1 98 100 00 rich +14.7 65.0 +16.0 -8.2 44.90 3.7
4468 +19.2 4.1 97 100 00 rich +15.1 67.0 +16.0 -8.2 44.90 3.8
4528 +18.0 4.1 98 100 00 rich +15.3 68.0 +17.0 -8.4 45.00 3.8
4655 +17.6 4.1 98 90 00 rich +16.2 69.0 +18.0 -8.4 45.00 3.8
4782 +17.8 4.1 97 100 00 rich +17.7 70.0 +17.0 -8.4 45.00 3.8
4880 +18.2 4.2 98 100 00 rich +19.2 71.0 +17.0 -8.4 45.00 3.8
5020 +15.9 4.0 98 90 00 lean +19.5 59.0 +18.0 -8.4 45.00 3.8
5420 +10.6 2.3 0 00 00 rich +10.7 14.0 ECU. -7.0 ECU. 1.8
4997 -1.4 1.5 0 00 00 lean +10.7 14.0 ECU. -7.0 ECU. 1.7
4498 -10.2 2.0 0 00 00 24.0 +10.6 14.0 ECU. -7.0 ECU. 1.9
4030 -10.2 2.1 0 00 00 24.2 +10.9 14.0 ECU. -7.0 ECU. 1.9
Discussion Starter · #2 ·
second part
The second log is just a run through the gears, again on level ground. Starting in 2nd gear and ending with a little bit of 4th gear.
3115 -11.6 1.6 2 00 00 24.2 +15.3 34.0 ECU. -7.0 ECU. 2.3
2677 -7.9 2.7 32 00 00 16.4 +19.7 12.0 ECU. -7.0 ECU. 2.4
2525 -3.2 2.6 41 00 00 13.6 +34.6 11.0 ECU. -7.0 ECU. 2.4
2620 -1.8 2.6 42 00 00 13.9 +33.6 12.0 ECU. -7.0 ECU. 2.4
2660 -1.2 2.6 42 00 00 13.8 +33.3 13.0 ECU. -7.0 ECU. 2.5
2741 -0.8 2.7 42 00 00 13.7 +33.3 14.0 ECU. -7.0 ECU. 2.5
2827 -0.4 2.8 42 00 00 13.7 +33.1 14.0 ECU. -7.0 ECU. 2.5
2861 +0.0 2.8 42 00 00 13.7 +33.0 14.0 ECU. -7.0 ECU. 2.6
2926 +0.2 2.9 42 00 00 14.1 +32.2 15.0 ECU. -7.0 ECU. 2.6
3000 +0.8 2.9 41 00 00 14.4 +29.5 16.0 ECU. -7.0 ECU. 2.7
3077 +1.7 2.9 41 00 00 13.9 +30.0 16.0 ECU. -7.0 ECU. 2.8
3159 +1.9 3.0 41 00 00 14.3 +29.4 17.0 ECU. -7.0 ECU. 2.8
3267 +2.5 3.0 40 00 00 14.7 +28.7 18.0 ECU. -7.0 ECU. 2.8
3353 +3.1 3.1 40 00 00 14.7 +28.6 19.0 ECU. -7.0 ECU. 2.9
3380 +3.7 3.3 94 20 00 14.4 +28.3 27.0 ECU. -3.8 45.90 3.2
3568 +4.7 3.4 98 30 00 rich +21.9 34.0 ECU. -3.8 45.50 3.3
3736 +6.4 3.5 98 40 00 rich +18.7 43.0 ECU. -6.4 43.60 3.4
3822 +9.0 3.7 98 50 00 rich +17.7 48.0 +17.0 -6.4 43.60 3.5
3982 +12.1 3.9 98 70 00 rich +16.5 56.0 +16.0 -7.2 43.60 3.6
4156 +15.3 4.0 98 80 00 rich +15.4 66.0 +16.0 -7.2 43.60 3.7
4317 +17.0 4.1 97 90 00 rich +14.3 69.0 +17.0 -8.2 44.90 3.8
4610 +18.6 4.1 98 100 00 rich +16.1 72.0 +17.0 -8.4 45.00 3.8
4844 +18.8 4.2 98 100 00 rich +18.2 72.0 +18.0 -8.4 45.00 3.8
5027 +17.8 4.2 97 100 00 rich +20.2 74.0 +18.0 -8.4 43.40 3.8
5282 +16.1 4.3 97 90 00 rich +18.1 77.0 +19.0 -8.4 43.40 3.9
5437 +15.7 4.3 97 80 00 rich +18.2 79.0 +20.0 -8.4 43.40 4.0
5564 +15.9 4.3 97 90 00 rich +19.3 80.0 +19.0 -8.4 43.50 4.0
5787 +14.9 4.4 97 80 00 rich +24.2 81.0 +20.0 -8.4 52.30 4.0
5995 +14.9 4.4 97 80 00 rich +24.8 82.0 +20.0 -8.4 42.30 4.0
6150 +14.7 4.4 97 80 00 rich +24.5 83.0 +22.0 -8.2 42.30 4.1
6397 +15.1 4.4 97 80 00 rich +27.0 84.0 +24.0 -7.2 42.30 4.1
6410 +15.1 4.4 97 80 00 rich +27.5 86.0 +24.0 -6.4 42.30 4.1
6734 +15.1 4.4 97 80 00 rich +28.0 89.0 +26.0 -5.6 42.30 4.1
6706 +11.3 2.6 0 00 00 rich +10.0 32.0 ECU. -7.0 ECU. 1.8
6172 -1.8 1.5 0 00 00 lean +10.3 32.0 ECU. -7.0 ECU. 1.7
4866 -7.3 3.6 82 10 00 lean +17.0 39.0 ECU. -5.5 45.00 3.5
4761 +1.1 3.9 98 10 00 rich -1.0 60.0 ECU. -5.5 45.00 3.7
4859 +10.0 4.1 98 60 00 rich +19.2 71.0 +22.0 -8.4 45.00 3.8
4894 +16.1 4.2 98 90 00 rich +17.3 76.0 +19.0 -8.4 45.00 3.9
5112 +20.2 4.3 97 100 00 rich +15.8 78.0 +18.0 -8.4 43.40 3.9
5232 +18.6 4.3 97 100 00 rich +16.6 78.0 +18.0 -8.4 43.40 3.9
5200 +17.2 4.3 98 90 00 rich +17.1 79.0 +19.0 -8.4 43.40 3.9
5324 +19.4 4.3 97 100 00 rich +17.7 80.0 +18.0 -8.4 43.40 3.9
5491 +17.4 4.3 98 90 00 rich +18.2 80.0 +19.0 -8.4 43.50 3.9
5574 +15.7 4.3 98 80 00 rich +18.6 80.0 +20.0 -8.4 43.50 4.0
5602 +16.1 4.3 98 90 00 rich +19.4 80.0 +19.0 -8.4 43.50 4.0
5678 +16.4 4.4 98 90 00 rich +19.3 81.0 +19.0 -8.4 52.30 4.0
5797 +17.0 4.3 97 90 00 rich +24.2 81.0 +19.0 -8.4 52.30 4.0
5963 +15.7 4.3 98 80 00 rich +24.6 81.0 +20.0 -8.4 52.30 4.0
5931 +15.1 4.3 98 80 00 rich +24.7 81.0 +20.0 -7.2 42.30 4.0
6082 +15.1 4.4 98 80 00 rich +25.1 81.0 +20.0 -8.2 42.30 4.0
6172 +14.7 4.4 98 80 00 rich +25.0 82.0 +22.0 -8.2 42.30 4.0
6265 +16.4 4.4 97 90 00 rich +24.9 81.0 +21.0 -7.2 42.30 4.0
6289 +16.8 4.4 98 90 00 rich +27.3 84.0 +23.0 -7.2 42.30 4.0
6325 +16.1 4.4 98 90 00 rich +27.7 84.0 +23.0 -7.2 42.30 4.0
6587 +16.6 4.4 98 90 00 rich +26.8 86.0 +23.0 -6.4 42.30 4.1
6510 +15.1 4.4 98 80 00 rich +27.4 86.0 +25.0 -6.4 42.30 4.1
6325 +13.9 4.4 33 00 00 rich +41.0 30.0 ECU. -7.0 ECU. 2.2
6082 +2.9 1.4 0 00 00 12.4 +10.4 30.0 ECU. -7.0 ECU. 1.4
5500 -9.6 2.0 0 00 00 lean +10.4 30.0 ECU. -7.0 ECU. 1.9
4585 -8.1 3.4 98 10 00 24.5 +21.9 34.0 ECU. -5.5 45.00 3.3
4572 -0.6 3.7 98 10 00 rich +20.7 49.0 ECU. -5.5 45.00 3.5
4681 +5.9 4.0 98 40 00 rich +16.8 70.0 ECU. -8.4 45.00 3.7
4642 +11.9 4.1 98 70 00 rich +16.8 73.0 +20.0 -8.4 45.00 3.8
4782 +17.6 4.2 98 90 00 rich +17.2 73.0 +18.0 -8.4 45.00 3.8
4768 +18.8 4.2 97 100 00 rich +16.9 73.0 +18.0 -8.4 45.00 3.8
4775 +17.6 4.1 97 90 00 rich +18.1 72.0 +19.0 -8.4 45.00 3.8
4810 +16.8 4.1 97 90 00 rich +18.3 72.0 +19.0 -8.4 45.00 3.8
4816 +17.6 4.2 98 90 00 rich +19.4 73.0 +19.0 -8.4 45.00 3.8
4960 +18.4 4.1 98 100 00 rich +20.3 72.0 +18.0 -8.4 45.00 3.8
4975 +18.8 4.2 98 100 00 rich +20.4 73.0 +18.0 -8.4 43.40 3.8
5073 +19.8 4.2 98 100 00 rich +16.4 73.0 +18.0 -8.4 43.40 3.9
4960 +18.6 4.2 98 100 00 rich +17.3 74.0 +18.0 -8.4 43.40 3.9
5005 +11.5 2.3 0 00 00 rich +10.7 2.0 ECU. -7.0 ECU. 1.7
4982 -1.4 1.6 0 00 00 15.2 +10.6 2.0 ECU. -7.0 ECU. 1.7
The last log is a roll on in 4th gear. You can see I get full boost around 3500rpm and I let out to avoid hitting fuel cut again ;).
2841 -1.4 2.6 21 00 00 14.7 +33.0 12.0 ECU. -7.0 ECU. 2.5
2834 -1.2 2.7 21 00 00 14.6 +32.9 12.0 ECU. -7.0 ECU. 2.5
2866 -1.0 2.7 21 00 00 14.4 +32.9 12.0 ECU. -7.0 ECU. 2.5
2873 -1.2 2.7 21 00 00 14.7 +32.9 12.0 ECU. -7.0 ECU. 2.5
2929 +0.0 2.9 96 10 00 14.4 +29.6 19.0 ECU. -4.9 95.00 2.8
2939 +1.9 2.9 98 20 00 rich +27.5 21.0 ECU. -4.9 95.00 2.8
2936 +2.9 3.0 98 20 00 rich +25.6 22.0 ECU. -4.9 95.00 2.8
2984 +3.3 3.0 98 20 00 rich +24.6 23.0 ECU. -4.5 66.00 2.9
3011 +4.1 3.1 98 30 00 rich +22.5 25.0 ECU. -4.5 66.00 3.0
3038 +5.5 3.2 98 30 00 rich +22.5 26.0 ECU. -4.5 66.00 3.0
3041 +6.4 3.2 98 40 00 rich +20.1 28.0 ECU. -6.7 66.00 3.0
3135 +7.6 3.3 98 40 00 rich +21.0 28.0 ECU. -6.7 66.00 3.1
3168 +9.0 3.4 98 50 00 rich +18.6 30.0 +22.0 -6.7 66.00 3.1
3205 +9.8 3.4 98 60 00 rich +18.3 31.0 +22.0 -6.7 66.00 3.2
3306 +11.0 3.5 98 60 00 rich +17.9 34.0 +22.0 -5.6 45.90 3.3
3290 +12.7 3.6 98 70 00 rich +15.7 39.0 +17.0 -5.6 45.90 3.4
3350 +14.3 3.6 98 80 00 rich +14.8 44.0 +17.0 -5.6 45.90 3.4
3377 +15.5 3.7 98 80 00 rich +13.0 48.0 +17.0 -5.6 45.90 3.5
3404 +16.6 3.8 98 90 00 rich +11.6 50.0 +17.0 -5.6 45.90 3.5
3512 +17.4 3.8 98 90 00 rich +9.0 52.0 +17.0 -5.6 45.50 3.6
3527 +17.8 3.8 98 100 00 rich +7.1 54.0 +14.0 -5.6 45.50 3.6
3584 +18.2 3.9 98 100 00 rich +6.5 55.0 +14.0 -5.6 45.50 3.7
3512 +18.4 3.8 41 00 00 rich +8.6 44.0 ECU. -7.0 ECU. 2.6
4006 +8.6 1.5 0 00 00 12.9 +31.4 19.0 ECU. -7.0 ECU. 1.4
3654 -4.0 2.0 0 00 00 lean +19.2 19.0 ECU. -7.0 ECU. 1.9
This last log is to show what kind of response the turbo has from a higher rpm roll on. This was while I was in 3rd gear around 4000rpm and punching it. As you can see I hit the gas around 4200rpm and by about 4600rpm I went from vacuum to about 23psi (relative autometer gauge indicated).
4145 -13.2 1.7 0 00 00 24.0 +16.5 1.0 ECU. -7.0 ECU. 1.6
4135 -12.8 1.8 1 00 00 24.0 +39.4 5.0 ECU. -7.0 ECU. 1.7
4166 -12.4 1.8 0 00 00 16.1 +41.7 5.0 ECU. -7.0 ECU. 1.7
4166 -10.8 3.1 62 10 00 14.1 +40.6 16.0 ECU. -5.2 ECU. 2.8
4187 -6.1 3.0 98 10 00 rich +32.9 23.0 ECU. -4.7 43.60 2.9
4208 -2.2 3.2 98 10 00 rich +31.5 28.0 ECU. -4.7 43.60 3.1
4262 +0.4 3.5 98 10 00 rich +26.9 35.0 ECU. -5.2 44.90 3.3
4290 +3.5 3.7 98 20 00 rich +18.0 50.0 ECU. -5.2 44.90 3.6
4380 +7.8 4.0 98 40 00 rich +14.5 71.0 ECU. -8.0 44.90 3.8
4468 +14.1 4.1 98 80 00 rich +14.1 72.0 +17.0 -8.2 44.90 3.8
4572 +18.8 4.1 98 100 00 rich +15.5 73.0 +17.0 -8.4 45.00 3.8
4668 +20.0 4.2 98 100 00 rich +16.0 73.0 +17.0 -8.4 45.00 3.8
4909 +19.8 4.2 98 100 00 rich +17.3 73.0 +18.0 -8.4 45.00 3.8
4982 +19.0 4.2 98 100 00 rich +18.9 74.0 +18.0 -8.4 45.00 3.9
5050 +17.6 4.2 98 90 00 rich +16.0 76.0 +19.0 -8.4 43.40 3.9
5027 +13.5 2.2 0 00 00 rich +10.5 2.0 ECU. -7.0 ECU. 1.9
4708 +0.8 1.4 0 00 00 lean +10.8 2.0 ECU. -7.0 ECU. 1.7
4268 -9.4 2.0 0 00 00 24.0 +10.9 2.0 ECU. -7.0 ECU. 1.9
All in all not to shabby if you ask me :). Like I said there is still some taper but I think that can be rectified with going with a stiffer springed wastegate. I am acutally planning on getting one in a couple of weeks with a spring tension of about 18psi. That should get me a nice 21-22psi to redline ;), instead of this wimpy 18-19psi to redline stuff [heh].
Awesome! Doesn't look like lag is THAT bad and your IDC #'s are so low for that much flow! Have you played with the fuel map a lot to get your duty cycles down?
Discussion Starter · #4 ·
Yah I think you can see in the second log around 6700rpm I am up at about 89% duty cycle on the injectors and that is only with 15psi (sea level equivalent) 18-19psi up here on the boost gauge. Which means if I can get the boost to hold to about 20-21psi I will be close to maxing out the stock injectors on a sea level equivalent of 16-17psi. That is with the a/f around 10.2-10.5ish I think it is up top = pretty rich.
And remember take those "lag" numbers and subtract about 500-600rpms for sea level boost response.
David - that is awesome spool up. Definitely a few hundred RPMs sooner than the '22 which is pretty darn impressive for a turbo that can flow 150CFMs more.
My TD05H cores are here finally. I had made up my mind on the 18G, but after seeing your logs I'm thinking that the 20G might be worth a shot. The big-16G that I'm having built for someone else is going to be one hard hitting s.o.b. that's for sure.
Thanks for obliging me with the logs, btw!
I know you had minor issues with the coolant bosses and lines with your 18G. However, my cores have all the correct coolant and oil lines/connections present, so fortunately for me that is one less thing to worry about. :)
-Pace
Phast...........11's!!!!!!! NICE.
Pace, 20G, I can't wait to get a ride.
David, looks like you have got quite a ride.
Looks like me baby is getting slower and slower by the minute.
I really think it is going to be an interesting year at Bandi. Looks like there will be a shortage of trannys here in the mile hi city! Better get my order in for a new one before you guys. :p
Todd
David,
Thanks for posting the logs. A few questions, do you have fuel rails, or even upgraded fuel lines?
I've heard that the 17c will tax the sti injectors to about 85-90% @ 17psi when trying to maintain a 11.1 a/f.
I will be able to verify more after I hit the dyno and check my a/f
Also, can you believe mine is still not here....oh well should be here this weekend.
Discussion Starter · #13 ·
All8up said:
David,
In those logs I was running STi injectors, GSS342 walbro and stock fuel lines. It was tuned for mid 10:1 a/f range heading to 10.2:1 at redline. I don't know if it shows in those logs but the highest I have seen duty cycles out my car and injectors to date is low 90% range.
Discussion Starter · #15 ·
Need4Boost said:
Any additional info? Price? Thanks.
Um not to much else. WHat other information would you like to know? I had this done custom/first so I paid a little more than others would I think. If you want pricing I would suggest calling Jim at TEC at 1800-950-turbo.
1 - 15 of 15 Posts
